LOGO
LOGO
My Hatz project has bee in suspended animation for lack of where to put the finished plane. All that has changed with a hangar becoming available at the closest airport to my home. Among the improvements being made to the hangar is scraping the rust off the small door. It is just ripe for a nice large Hatz logo. Does anyone have a cad or graphic file of the Hatz Logo that they would share?
- splischke
Re: LOGO
Perhaps the following files will be of some help. I did the artwork for the wings but I'm still working on the font. It's close but not exact. All attached files are the same logo just in different formats. All are vectorized and can be made any size without loss of detail.
- hatz.ai
- (107.1 KiB) Downloaded 710 times
- hatz.dxf
- (952.51 KiB) Downloaded 648 times
- hatz.pdf
- (117.78 KiB) Downloaded 679 times
- hatz.png (97.96 KiB) Viewed 18812 times
Re: LOGO
Those will work great. I am horrible at doing anything freehand, especially since I started using a CAD program at work. One of these will make a template si I can paint by number.
Re: LOGO
I don't know how much help this will be, but I have the following:
The logo is clearly not print ready, but if you knew how (or knew someone who could) clean it up then you have a starting point.
The photo is from John Kerr's Hatz Classic. It looks like a vinyl sticker. Don't know where he got it but you could try him. Others have done the same so I'm sure they are out there.
- Hatzwing.jpg (39.45 KiB) Viewed 17156 times
- Hatz biplane 016.jpg (141.53 KiB) Viewed 17156 times
- Dana
Re: LOGO
I found the logo offered in several versions as vinyl stickers. May be where the ones on my plane came from.
Also not camera ready:
I guess I can scan a sticker... or just photograph my plane.
- Dana
Re: LOGO
My daughter got a cricut vinyl sign cutter, so I asked if she could make a sign for my hangar door. I couldn't find one to match the one on my plane with the cool art deco font, so I finally broke down and made a high resolution version, photographing the one on my plane, tracing it in my CAD software (Keycreator), exporting it and doing some post cleanup. This one is 14476 X 4975 resolution, and cut OK, though some of the lines are a bit thin and hard to peel off the backing.
- Hatz logo.png (367.63 KiB) Viewed 11814 times
